Steering Wheel
SephirotH
Do you do any damage to standard steering wheel (Airbag Type) when you replace with an aftermarket one.
Can I change it bag to old one afterwards?
Should be able to as long as you dont set it off!! i think you will need an airbag simulator device to avoid getting an airbag light on the dash once you install your new wheel. Disconnect the Battery before carrying out any work on SRS system
