Tte Springs
robtheman
I am thinking about ordering these springs from my toyota dealer for £148.
Did any of you guys really notice a difference from standard facelifted T-sport handling?
Or is it just a waste of money that could go towards a K&n Typhoon!
cheers :)
cheers :)
Why don't you do both?
Add a bit more power but improving the sloppy handling of our Rolla! :yes:
I always go for a proper suspension kit rather than just changing the springs unless your car is nearly new! 2 very good kits (Not bad £ wise) are Bilstein and Koni! The dampers are specifically tuned to match the lower springs! Unlike the Japanese stuff, these are tuned for European road!
cheers :)
blistein are ok, well koni is koni .
japanese stuff are the best for japanese car's and i know i take tein,cusco,hks suspenion over any of the make you mention above for my tsport anyday and it has been mention a lot of times on here by tsport owner's to all tsport owner to get teins suspenion setup if they can for for their corolla tsport i wonder why ?.
robtheman i say go for suspenion setup first and if you are getting the tte spring then i would suggest you change the shocks too if not you be like me you will be paying for the same job twice.
tte spring with standard shock does not give you big handling different to your car it will still be like jelly handling wise you need to change the shocks to get decend handling, having own the tsport for over 3 years coming up to 4 i can honestly tell you changing the shocks is a must for better handling.
Thanks for the help!
apoligies i confuse easily.... :huh: lol
So which combinations are best?
coilover kits
lowerings springs + Shock absorbers
Rob
coilover kits
Rob
Rob after you buy lowerings springs + Shock absorbers you might aswell go for
adjustable suspenion kit i cant see the price would be that much different maybe a little more but it would be worth it .
coilover kits
Rob
Dont listen to this lot about the tte springs not making much difference. They transform the car whilst keeping the ride comfy. My car goes round corners much better with tte springs fitted. You can even fit them yourself if you are handy witht the spanners
Hey up t sportkid have u a quick guide for fitting these springs yourself i'm getting a set too and if i had a guide about fitting them i wouldn't have to take them to mr t to fit and take my money cheers mate! :thumbsup:
kool....
You say the ride is still comfy which is a bonus!
what about spped bumps? any probs here...
I will still get them if anything they make the car look better :D
I run on Eibach Pro springs which drop the car the same amount. Speed bumps really aren't that bad on mine - the ones that were vicious are still vicious and the soft ones are still soft.
Obviously the springs will make everything stiffer, the pay off in the handling performance really outweighs the slightly harsher ride.
Unless you do some serious driving, I think adjustable suspension is overkill. The TTE springs will sit on the standard hocks without a problem and coupled with a front and rear strut brace (if you can get hold of them for a decent price) will tighhten everything up nicely for standard (but fun) driving.
coilover kits
Rob
i suppose you mean me yes dont listen to me lets all listen to you tte are the best everyone should get it ! :D
watever later's
