Electrical Quiestion
natt
hi. im fitting an aftermarket rev counter to my 94 corolla sportif. im not very good with electrics but ive worked aout most of the wiring except one. on the instructions theres a wire thats to be connected to the negative terminal of the coil, as far ias i can see, the coil and dizzy are all one unit so basically ive no idea which wire i have to connect it to. im having a look at the wiring diagram to see if i can work it out but im not the sharpest knife in the drawer so prob end up giving myself a headache. can anybody shed some light please? its the 4E-FE engine by the way. (i think)
thanks. :)
ok. ive just been out and had a look under the bonnet. as far as i can see the coil an dizzy pack has 2 multi-plugs going into it. one plugh has 4 wires, the other has 2. from what i can disect from the haynes maunal the 4 plug is for the dizzy and igniter and the 2 plug is for the coil. before i start pulling and chopping away, is there any way i can test with a multi-meter to make sure that the 2 plug is in fact the poss and neg for the coil? thanks.
