A Brake Question
Lil_Pike
The last 2 weeks i noticed that and rolling at about 5-10mph if i turn the steering to the left or right the brakes squeal...?
Has anyone had this problem?
I've ordered upgraded discs and pads anyway but i'm not sure why this is happenin?
can anyone shed some light on it?
I'm sure it's something to do with the metal plates surrounding the discs, it may be catching on something. (not sure what they are called)
Try bending them in towards the arch, away from the disc and then see if it makes a difference.
Think you should check the brake pads as they are probably low and the safty metal piece is scrathing against the disk.
If its as simple as that then you just need new pads.
  • 2 months later...
