Wheel Bearing Replacement
pacey
:help: has anyone replaced a front wheel bearing on1600 corolla 98 model with ABS or is this best left to skilled mechanic. Any input would be appreciated
you need a press to get the bearing out, if you haven't got one, then leave it.
alternatively, if you get the stub axle off, give it to a mechanic and then let him do it, you could save money.
pacey
Thankyou for your help I will probably leave it for a garage.many thanks
