Fault Code
Banjo
Hi ive been getting fuel cut so ive bridged E1 and TE1..... Fault code came on and there were 5 flashes then a delay then 1 flash on managment light...Does this reset something or is this the code for whats wrong with my car??
Check the fault codes, try pulling the the EFI fues out or disconnect the Battery and then test for FC's. If you just a get a quick constant flashing then there are no errors stored
