I Am Desperate! - pcv valve help?
93_4afe_TRD
Hey everyone,
I posted a thread a little while ago about a PCV valve, for some reason no auto repair manuals explain how to get my PCV valve off, they just say once it is out, do this. I AM FRUSTRATED. My 4afe does not just pull out and i am stuck. If anyone can help in any way, that would be great. Thanks everyone.
-Greg
Not that familiar with Celica Engines......but if it's anything like the Sera then the pcv valve just pulls out of a grommet. The problem is usually that the rubber grommet has perished and become hardened - so the valve is jammed into the hard rubber. It pulls out ( eventually - with excessive force ) and usually disintegrates when it's forced. New ones are cheap enough though.
No idea if this helps though.......It may be the same on the Celi though, so it's worth a mention.
Good luck
Rich
