Another Tte Owner Here!
banana man
hi everyone,
i'm new to this forum and to the land of Toyota. Just got myself a newish TTE compressor 55 plate in granite. As i'm new to toyota ownership can anyone fill me in on the model, engine codes body codes etc.
Also what grade of oil should i be using. as its due a change soon?
Cone or panel filter?, and where would i be able to get one,as they are only listed for a T sport. :unsure:
Anyone recommend any decent brake upgrades as the ones on the front are a bit soft and quite frankly covering ma wheels every 5 minutes with dust. :eek:
Cheers :thumbsup:
im sure the air box on the compressor is the same as the t-sport........
engine code for the t-sport is 2zzge which apexi do a dry panel filter..........well worth the money.....
brake wise, i'd go EBC pads and 3g discs or black diamond discs.
Chassis code is E12.
Oil is recommended at 0w30 or 5w30. I personally use 0w40 (Mobil 1)
and welcome!
Hi and welcome,
Post some pics of your car ;)
al get some pics up as soon as the car comes back from the garage, air bag light started coming on. :huh:
I was thinking of the TRD panel filter bit expensive though, can you also tell me about the inlet silencer and where it is located
as for the brakes i take they are the same as the T ports then,any companies do upgrades ie bigger discs and decent calipers.
sorry to ask so many questions just trying to quickly get myself clued up,as parts seem to be scarce.
