Recomended Gear Box Oil
den9112
hi, can anyone recomend a good oil for my 1995 rav4 manual gearbox . cost of oil is not a problem . thanks
my manual says
gear oil type API GL-5
SAE 75W-90
As for brand, I expect some members out there can recommend some.
my manual says
SAE 75W-90
thanks , i hope someone can give me a good brand as my gearbox is a little worn but still acceptable , i would rather put good oil in rather than cheap stuff.
my manual says
SAE 75W-90
good quality oils from this company. http://www.millersoils.net/index2.html
We have used Miller oils too and found them to be excellent. Synthetic oils seem to be better for older gearboxes than mineral ones.
Whatever you do, don't be tempted to put any slippery additives in your gearbox - in my experience they stop your synchromesh from working. I've thrown away two gearboxes after putting that sort of stuff in.
Finally, whatever you do, don't be tempted to put any slippery additives in your gearbox - in my experience they stop your synchromesh from working. I've thrown away two gearboxes after putting that sort of stuff in.
thanks for the info
