Wheel Trim/cover Size For A Mk 1 Avensis?
noddydog
Either one of my front wheel covers fell off or some idiot stole it. Either way I'd like to replace it. How do I discover what the wheel size is? It's the standard set of wheels and trims that the car was shipped with. I took one off and measured around the metal inner ring and it showed 14.5 inches. However when I look on eBay no one is selling wheel trims in this size. So what should I be looking for?
Go & have a look at your tyres, they will have the sizes written on the sidewall, e.g. 205/55/R16 The last digits being the wheel size. I should think yours will be 15" ;)
Thanks guys. I've worked out that they are 15" since the tyre has R15 at the end. Re the eBay auction they are not the same ones on mine, but thanks anyway. I guess I might as well buy 4 none Toyota ones on eBay.
make sure you buy wheel trims with FIVE wheelnut holes and they are at the right spacing from the centre of the wheel - it wont fit otherwise.. try to get toyota ones if you can as the plastic is more flexible and won't chip so badly.
