Dump Valve Fitting
98 ST205
hi all,
i need some help.
i am after buying a HKS SSQV dump valve but only bought the unit, i dont have a fitting kit for it, (Am i after doing a stupid thing by just getting the dump valve?)
do i need a fitting kit (if so where can i get one?) or is it easy enough to make up one.
im not sure where is the best place to put the dump valve.
any information would be appreciated...
cheers.
if u buy a fitting kit for your model u should get instructions for fittin it yourself :)
assuming you have an ST-205. look on the front of the charge cooler and you will see two pipes one large one connected to the turbo and a smaller one that goes to the stock BOV on the airbox. now you have a choice, either disconect the stock BOC and connect the new BOV to that end of the pipe or remove the pipe and connect to the CC using a short length of pipe.
the small vaccume pipe connects to the same place as the small pipe fom the stock BOV.
leave the stock BOV in place or get a blanking plate made for the airbox :thumbsup:
cheers lads, the only fitting kit i could get my hands on was a HKS universal fitting kit, it needed a small bit of jiggin and playing with to get it fitting perfectly, i placed it in where the stock BOC was situated and put a blank on the back of the airbox.
its in a couple of weeks and im loving the sound off it.
thanks for the reply...
