4age Head!
Dof
Does any1 know the size of the head bolt on a 4age engine!! I've tried loads of different sockets but none seem to work!!!??
10mm sockets but need to be long sockets 10mm in size and 10cm long
cheers Just tired it! mine isn't 10mm head anyway. doesn't even fit it. It fits 11mm good but when u put any force on it , it just turns but not the bolt!!! This is really ****** me off..... I am actually considering drilling out the bolt heads(Very hard cos there made of hardened steel) and if that does work......i am seriously gonna cut into d head to the bolt shaft!! and buy a new head!!! Can any1 help:(???
The cylinder head bolts (which you will NOT re-use -buy new!) on the 4AGE engine ARE 10mm! ...
...but...
...they are 'double hexagonal' type!
Thus you will need to use a '12 point' socket (I presume you've been trying a 6 point/sided socket?)
**These bolts almost look like a sort of 'star' design in their shape which can be confusing!**
Hope this is the answer to your question.
Legend!!!! Thanks so much!i'll give it a try
Yeah worked a treat! Thanks again
With regards to this 'style' of bolt/nut you may find that some of the pulleys on the engine are the same.
Memory fades but I think the timing belt tensioner is fixed in this way (and you will need a long socket for a dowl/rod potrudes through it, so to speak.)
Yea noticed that! Good memory cheers!
Incidently 4AGE cyl head bolt Torque settings are:
Stage1 - 29 Nm (in seq.)
stage2 - Another 90 diagrees (in seq.)
stage3 - A further 90 diagrees (in seq.)
As another bit of info some people I have been talking to have re0used the bolts on these 4AGE Units with no probs!
...so it's up to you (personally I would buy new)!
