Avensis Engine Probs
zaf50
Hi have a 1.8 VVTI Y reg 2001 Avensis and recently have rebuilt and replaced the engine, finally once everything was more or less finished started the car within 2 mins the engine cuts out.
Thought it may be the injectors replaced those with a spare set I had. made no difference
Would be grateful for any suggestions and will further try to resolve tomorrow?
is the ECU original or from the donor car?
HI ECU from original car only fitted brand new short block and recon head all other ancillaries from original car
Still cannot figure what is wrong, my only suspicion at present is still the injectors, I think its the seal WOULD REALLY APPRECIATE SOME FEEDBACK IF POSS?
is there an error code available?
I don't have the expertise to help really, but have heard of ECU problems on donor engines. This shouldn't be your problem as you didn't change the affected bits.
compression test? Immobiliser?
Hi many thanks for your reply got another set of injectors with new garnets and hey presto problem solved, however now the engine management light is on.
Can anyone remind me how to reset the, was it the EFI fuse?
