TOWNACE EXPERT ADVICE REQUIRED
Help/info Please. New member
I just bought a 91 townace 2.0 turbo diesel off eBay I am losing water I have no leaks if I top up into engine and start up with cap off I can see water level falling small bubbles escaping also.
I dont seem to have much power it will only do about 65 miles an hour the turbo light on speedo does not come on while driving it comes on when i first turn ignition key on so bulb test is ok.I can hear turbo whistling slightly when accelerating I can do the work myself but would like a bit of help from anyone who has had experience of these problems .
looks like air con is not working pump pulley is not coming in when I select a/c I suppose this means it will want regassing
What a shed.
i dont know if you have fixed the problem with the head gasket, if not then i suggest this....
http://cgi.ebay.co.uk/K-SEAL-HEAD-GASKET-R...M-THE-ULTIMATE-SEALER_W0QQitemZ140107551818QQihZ004QQcategoryZ72205QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
copy past the whole addy.
this stuff works wonders, i know coz i had a blown headgasket
along with a cracked head and it cured both.
good luck :)
