Resetting Management Light
zaf50
Hi any thoughts would appreciate needed an 02 sensor found out using testing kit which I have replaced with a generic one.
The management light is still have tried the trick with EFI fuse did not work
Any suggestions
Which model do you have?
I understood that generic O2 sensors won't work on the 4A/7A range? It has to be a genuine part.
need correct part and ecu will cause the the fuel to be too rich are you sure o2 duff?? how old the car a sooted up o2 sensor is not duff its a sympton of over fueling
?? p420 or p430 code means new cat ecu and labour best part of £1300
kick off with dealership
