Fuel Pump
Banjo
I am needing to fit an uprated fuel pump to a ST185, and im not sure if i can get it fitted while the tank is still in...or do i need to take the tank out??
the tank will have to come out im afraid.
would be worth checking out the condition of your pipes firs though as if they're corroded they will most likely break when removing the tank.
Thanks for your help...it wasnt really the answer i was hoping for, thought i could have got to it from inside the car.....typical nothing is simple with this car!!
Bet you the actuator is going to be a pain in the butt too!! You got any suggestions on a good one??
