Apexi Power Fc
damo746
Hi all I'm newish to this but I need some help and I thought this is the place to get it so here goes. I've had my 53 plate cts for 6 months done the usual mods like typhoon kit, strut brace, lowered suspension and I must say this car is awesome i've never smiled so much as I do when dring the cts. Anyway i've just bought an apexi power FC with controller very cheap and now i'm after someone to fit it and set it up so if anyone knows of someone in this area I would be greatly appreciative of their contact information thanx.
Also what sort of gains can I expect from this piece of kit?
Well fella you should get some reasonable gains from it, changing lift engagement is possible and if removing the cat you should be able to get better gains! your problem is not many people have this kit or have been put off the idea in the past. The problem is its gonna need a lot of wiring, as the wiring harnes that comes with it isn't an exact fit for thr corolla ecu, all power fcs for the 2zz-ge engine fit celica ecu as standard, unless they have changed things around and developed one for the corolla!
Anyway your best bet is driving to somewhere that is known and handles Apexi kits, i would suggest thor racing, or if anybody knows of someone else they will probably post it up for you!
Hope that helps!!
p.s It may be a good idea to ask the same question in the celica forums, as i have heard of a few celicas running the power fc. They may be able to point you to somewhere closer to home!
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
