Rear Shocks For 1994 1.6 Carina E Estate
k_macmillan
Hi Folks
Having just checked my rear shocks i see that both have leaked out their oil, which explains the noisy bumps of late. Whats your advice on replacement? Should i stick to Toyota's own parts or are there decent cheaper alternatives. Is this a garage job? Or is it possible to do without special tools.
What sort of price should I be looking at from a garage?
Any advice much appreciated Cheers
Copy Munroe Shocks are around £40 each. Cheaper parts are also available. Can't comment upon originals. I've only replaced the rears on my old Corolla but the process is identical.
It is a straight-forward job which requires a set of spring compressors and a socket set. The only possible issue I would think is the splitting of the brake-pipes. If they are original the union between the rigid and flexy will be very rusty. You will need a pair of locking pliers (mole grips) to split the joint. Otherwise a simple 90minutes per side.
A garage may charge a couple of hours labour so £175 - £200 all in.
Parts also available:
http://cgi.ebay.co.uk/TOYOTA-CARINA-E-REAR...1QQcmdZViewItem
Just got a quote of £170 supplied & fitted from my local National Tyres place so that seems about right.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
