Reversing Light Doesn't Work
Robin H
Hi people
Got a problem with our mk1 yaris, The reversing light doesn't work!!
I've put a new bulb in the back and just fitted a new switch to the gear box to say when the cars in revers and still no joy :(
is there a separate fuse for the reversing light anyway or is there some thing I may of over looked ????
thanks in advance
Robin
plastic bracket that holds the metal pins in place may have broken? mine did and cost about £5 from mrT and dont listen to garages saying you need a whole new light assembly, i was nearly caught out!
just fixed the problem :D
thanks for pointing me in the right direction Rickster
just been out with a meter to go through the electrical circuit
checked the new switch in the gear box we fitted that worked fine
tested the plug on the rear light cluster that worked fine
tested the bulb that was fitted that worked fine
tested it when in the bulb holder that was fine
checked all the wire in the light cluster thats was fine
put it all together nothing didn't work
I swapped the plastic bulb holders round ( 1 from the fog light ) that worked woo hoo
after much swapping bulbs around in the plastic holder I discovered that even though the bulb worked in the holders 1 didn't when you put it back in cluster
with a bit of bending the contact tabs that touched the bulb and cluster it now worked again
