I Appear To Have No Hazard Lights!
SupraBen
Indicators work fine but the hazard lights don't! :o
Is there a separate fuse / relay for them or is it likely to be the switch?
Cheers
Ben
Yeah there is a seperate relay i think. But check the fuses first, ya never know. Actually i should check mine. My brake fluid level warning light doesnt work and neither does the aircon....oh and the drivers side central locking...only locks....balls
Turned out to be a fuse in the fusebox adjacent to the Battery in the engine compartment.
It had taken out the hazards the horn and the motors that drive up the headlamp pods.
Behind the kick panels in both front footwells there are a host of relays with no indication of what they do.
I'm still unable to work out the wiring for the radio, someone had kindly cut the plugs off, there are about 18 different wires, currently considering ignoring the Toyota loom and rewiring the radio from scratch.
Allegedly there is a factory fitted amp somewhere which would account for why the speaker wires don't match any of the wires in the centre console.
Deep joy!
Toyota tend to hide their amps in supras under the passenger foot well....
Some one also kindly cut the wire sin my girlfriends '91 turbo, not content with this, they then decided to rewire a standard DIN plug into the tattered remains of the toyota loom.
Rewiring from scratch is definitely the way forwards!
