Brake Caliper Bolts Torque?
akjenks
Hi guys, Iam changing the the front pads on the wifes e12 and wondered if someone had the correct torque settings for
1, the caliper to carrier bolts
2, the carrier bolts
3, the wheels nuts.
I need the carrier bolts torque as i am taking the opporunity to paint the brakes in silver to make them look better. I will put up a post afterwards. Cheers Andy
caliper to carrier bolts 42nm
carrier bolts 87Nm
wheel nuts are 92Nm
these numbers are off the top of my head but i'd say they are within 5%.
Just a note but you don't need to undo the carrier/caliper bolts to change the pads.
