Turbo T Sport
ShamGTTurbo
Is there a turbo kit for the CTS?
Also will you need to upgrade the internal of the engine to turbo it?
Lower Compression pistons, stronger rods, crankshaft, ect ect...
Cheers
Sham
You can save run 10psi on stock 2zz
read this and there are more usefull info on that forum
http://newcelica.org/forums/showthread.php?t=199226
I have never seen CTS turbo kit but maybe you can fit some turbo kit from a celica and mix that on :)
hope that helps..
  • 4 weeks later...
according to the add its the same supercharger kit thats used on the orginal compressor and you get everything you need charger pipe work extra wiring and the ecu needed to run it all
