After Market Brake Pads
Ckman85
hi guys, im sure im not the only person here that thinks the stock pads on the Corolla E12 r a pile of S**T and dust comes out like no bodies business.
Well i just want to know if i put aftermarket pads, will it void my warranty? also wot pads wud u lot recommend?
Thanks :thumbsup:
no it won't, brake pads and other consumables (such as Wiper Blades, tyres etc) are not covered under the warranty.
and i agree like yourself the OE pads are cack.
I'd go Endless SSS or EBC Greenstuff.
Often wondered about it .....
Cheers :thumbsup:
So do you have anymore info on the pads ie which is best, price etc as mine need replacing and Toyota want £220 in total
Im fed up of my wheels being black lol
well i checked out motorsportworld and they r selling ebc green stuff pads for £47.48 (front) £42.25(rear) with an xtra £7.50 P&P, not sure if itll cost that much to send both. do u think i shud take my car down to Mr T tomorrow and get them to check out the standard brakes and ask if they wud void my warranty if i was to get after market pads. Or shall i just buy the pads?
I would buy them anyway.
although it seems a bit expensive. you tried ebcbrakesdirect.com?
Brakes/Tyres/Coolant/Oil/Filters/Air Con fluid/Wipers/headlight bulbs are deffo not covered under warranty.
well ive just ordered some EBC green stuff pads front and rear from motorsportworld, came upto £97.32 inc P&P. My next question is, can some1 tell me how to fit the pads, im tempted to giv them a go myself, i dnt really wanna pay some1 to fit it for me :D
Cool .... when i've got some dosh i'll think i'll get a set :thumbsup:
I'll also find out whether they do or don't void your warranty ... as mine is due pretty soon and i'm looking at extending it ;)
Let us know how you get on
here's my guide to changing pads and discs which i posted a while ago, the setup on a T3 is the same as a t sport (my car) but the disc size is different. so it sould be straight forward.
http://toyotaownersclub.com/forums/index.php?showtopic=56738
you only need to do steps 1 to 6, and step 19. the backs are the same as the front on an E12 corolla,
hope this helps
Erm - how do you tell which ones you need????
Is there a model number I can check agaisnt listed anywhere??
Mines a E12 04 2l D4D :wacko:
There's two on the list and i'm not sure which one it is
wot site u using? i checked out motorsport world and like u said theirs 2 choices which i dnt hav a clue lol. i just recieved a invoice from motorsport world and it says for 3dr saloon :wacko: ive emailed them bout the order and i havnt recieved a email bak yet. But can some1 tell me here if the pads wud fit my car?
much appreciated
Looking at the actual size and shape for the 2.0 D4D, the DP21457 model ones(front pads) look like the correct fitment as the others are much larger and squarer in shape.
Although to add a disclaimer, as I've never seen the pads from the 2.0 diesel, I can not guarentee thast this is correct.
Is there a way to check ie by looking for a number on the current pads? (don't want to take the wheel off)
I used the motorsport world website ;)
I guess there must be a code I can get from Toyota that will match the MSW code??
I'll wait for nrgizerbunny as it seems he knows abit :P ;)
DP21457 is the correct part number! This fits all UK E12 corollas.
the difference between the diesel/t sport/normal petrol is only the brake carrier, the caliper and the pads ARE THE SAME.
also if you have a look at my brake fitting guide, see if your pads look like the one in the picture.
Anyhow I can guarantee 100% that the DP21457's will fit. If you want the rears, then send me a PM or post your car details up here and i'll send you the part number for your car. I have the EBC book in front of me!
have a nice day
sanj
have a nice day
sanj
Legend :thumbsup:
On a slightly related note, I noticed yesterday that my front discs are quite badly "grooved" where the pads make contact (can't believe I've not noticed before) so I am looking for some Black Diamond Combi front discs and I'll also chuck some green stuff at the car too whilst I'm at it. So where's the best place to pick up som BD combis from?
so r u saying i can actually get aftermarket brakes aswell as pads and it wont void my warranty?
I've seen people on here getting their discs replaced by Mr T during their warranty period so I would imagine they are covered so you won't be able to replace them if you like your warranty intact. It makes no difference to me anyway as my warranty ran out at the end of December so I've been happily replacing bits myself since then :thumbsup:
arhh thats a shame, well i still hav 1yr and half till mine runs out :crybaby:
Also i recieved the pads today, u get 4 pads in each set, so not bad, just means once a pair of the pads runs out i can just fit the others :D
i hope to fit them sunday so ill post sum pics :thumbsup:
basically anything that is consumable that wears out through use is not covered by warranty. therefore tyres which wear out or brakes which wear out will require replacing at the owners cost (as its not toyotas fault of the car has been ragged).
If there is a fault that is not through wear, ie the disc has warped or 4 tyres have catastrophically suffered blowout, then toyota are required to change them.
If you change your brake discs then the warranty on defects passes from toyota to EBC/black diamond or whoever.
The use of aftermarket brake pads (provided they are of the same spec or higher than OE) will NOT affect your warranty. This is also covered by the EU block exemption agreement which allows you to fit non manufacturer parts (OE spec though) to the vehicle and keep your warranty. some more info is here.
http://www.dti.gov.uk/consumers/fact-sheets/page29050.html
This scenario is no different to the situation that would arise if you swapped out your head unit for a pioneer or something. the warranty is taken up with pioneer on the headunit and not toyota. hope this clarifies things.
I would go motorsportworld to buy discs and pads, they are pretty good.
have a nice day
sanj
heh shows what I know then eh? ;)
And motorsportworld are no good for discs as they don't sell the combis for the cts (unless they do but haven't got them listed on the site).
Hi Ckman85.
By the sound of your last message you are only planning to change a set of pads on one wheel only!!!
When ever you put new pads on you MUST change both sets at the same time, or the brake balance will be out.
OK will give em a call as I also have to call europerformance and venommotorsport because no one seems to be willing to have a price for them on their site. I guess they all order them in because there's probably not much demand.
p.s. I'll try my best to shut up now and stop the thread hijacking ;)
black diamond part number is KBD 1209 for t sport front discs. i think they sell direct too so you could try ringing them 01704 893939
Hi Ckman85.
nope, im changing the front 2 and back 2 pads, but front and back pads r different size so i had to buy front pads and rear pads, but u get 4 sets of pads in each box.
