The Perfect Car Washing Guide...
Fizz
One of my least favourite parts of the car cleaning process is washing! yep, that's right, I hate it, loathe it with a passion bordering on the psychotic.
Why I hear you ask? OK, the wash process is when you risk causing most damage to any paint finish as there is constant friction between the washing tool and paint and any dirt on the surface can act as a scourer, leaving more damage, more swirls and more work ultimately.
With this in mind, I figured that other people might be having the same issues so I've compiled a 'how to' guide. This is by no means a definitive (you can only wash your car this way) gospel, rather, it's a bunch of hints, tips and 'do's and 'don'ts' which may be helpful.
Sun or Shade?
Traditionally, washing your car in bright, hot sunshine (which we of course experience a lot of here in the UK…) was always a no-no and whilst there are some shampoos which can and do work reasonably well in sunny conditions, I always try to avoid this as water spots very quickly on paint and glass, shampoo dries streaky before you can rinse away, drying towels drag on water spots, causing scratching – plus the folically challenged always end up with a sunburnt head!
Which shampoo?
There are a lot of shampoos available both off the shelf, via the Internet or from specialist companies who supply the trade. I usually steer clear of “wash & wax” type products, as they rarely use a particularly good quality wax and I want pure cleaning power from my shampoo (now, THAT sounds like an advert for washing powder!)
Expensive shampoo is something I usually avoid, not because I'm tight, but because they rarely out-perform lower priced products. I always look for shampoo that doesn't strip any wax from the car and ideally one which sheets water off the surface (more on this later) Sonax Extra Gloss and Mothers California Gold are particular favourites for this reason.
Process
I always evaluate any car I work on before doing anything to it. Look for any damage, corrosion, bird mess etching or other fallout and decide on the best route to removal.
I then rinse the car with plain tap water from the hose. Spend a good few minutes doing this, as pre-rinsing will help remove any dust, loose dirt or mud from the car, reducing the risk of this causing damage to your paintwork.
Mix your shampoo as directed – you can use either cold or lukewarm water, not hot as it can either strip wax or reduce its ability to protect, plus it'll burn your hands…..
Get a second bucket and fill with cold water.
Chuck out that sponge!!!!!!!
Yellow sponges are, in my humble opinion, the single biggest cause of wash damage. They trap dirt on a flat surface and simply move it around the paint, making the dirt particles like a scouring pad on your pristine paintwork. Even regular rinsing can't overcome this problem, so what can you do?
Easy, invest in a lambswool washmitt. Does exactly what it says on the tin, in that most have a synthetic mitt that you fit your hand into covered with a thick layer of genuine lambswool.
Why stick your hand up half a dead sheep? Why not I say – whatever floats your boat……
Seriously, lambswool is softer than a synthetic sponge and draws dirt deep into the wool, and away from your paint. It also rinses cleaner and dirt is not trapped as easily, thus reducing the risk of damage.
You can clean them in a mild liquid detergent and I have mitts, which are close to 2 years old and still work well. Chenille and microfibre mitts are also available, but in my experience lambswool performs considerably better.
Back to the process…..
Don't be a scrooge!
You should now have the following tools.
1. Bucket filled with shampoo mixture
2. Bucket filled with cold water
3. Washmitt
4. Hosepipe
This is the order in which I wash my Astra hatch.
1. Roof
2. Side windows
3. Bonnet
4. Sides to rubbing strip approx 1/3 from sill height
5. Rear window/boot
6. Front end
7. Windscreen
I try to follow the logic that, under normal use, area 1 stays cleanest and area 7 collects the most dirt, bugs and so on.
Put mitt in bucket, onto panel and soap thoroughly and here's where you don't need to be (and mustn't be) stingy with your shampoo mixture! use plenty as the soap is both cleaning and providing lubrication (no sniggering at the back please) between your mitt and the paintwork. You can always make up more if you run out! Try to work in straight lines to minimise swirling. I generally use the following rule;
Horizontal panels (roof, bonnet, boot) – front-to-back-motions
Vertical panels (doors, wings, front & rear) – top-to-bottom motions
After each panel, dip the mitt in the clean water bucket, rinse and continue. I generally change the water every 3rd panel or more frequently if the car is very dirty.
I tend to do the roof and side glass, then rinse, bonnet, rinse, side 1, rinse, side 2 rinse, tailgate, rinse, grill, rinse, windscreen, rinse.
I then switch to another bucket, make up more soap solution and clean the sill panels, front and rear bumpers and rinse.
You can use 2 or even 3 clean water buckets (I do this on my black 205), Grit Guards on your rinse bucket, different mitts for different areas – your choice really.
Get your end off
Finally, remove all couplings from the end of your hose then use the stream of water to get as much water from the car as possible – the less water left, the less drying needed.
Drying
Get a good microfibre waffle weave drying towel. These are heavier microfibre towels, with pockets that soak up water very quickly 'some won't' even wring out after drying 2 or more cars!
I tend to use several towels on a rotation basis when I dry cars and blot water spots. I also use a lightweight waffle weave which absorbs less water but is lighter than most drying towels.
Meguiars Water Magnet is the best drying towel I have used so far – absorbs a lot of water without becoming heavy.
Always dry in straight lines – I dry front to back on all horizontal panels and top to bottom on all vertical panels. Don't forget doorshuts, petrol filler and boot/bonnet shuts (I have several older towels for these areas)
You can also use some QD spray whilst drying – just make sure it's compatible with any wax on the car to avoid streaking.
Conclusion
This guide should help you to maintain the perfect finish and reduce paintwork damage during washing.
You can add a lot of tools, products and other techniques into the wash process but I have tried to stick to the basics rather than confuse everyone. :thumbsup:
http://video.google.co.uk/videoplay?docid=...how+to+wash+car
  • 3 months later...
Can i bring my car to you?! :lol:
Ohhhh what a good guide.
Was worth the cash, plus you only have to buy the mit and buckets once. and then you get loads of car shampoo anyway.
Nice and shiney again :yahoo:
get some pics up then boyo!
Gaz - I copied the guide from elsewhere.. i dont wash my own cars now since it aint nothing special.. :(
  • 3 years later...
Excellent guide. I wash my car in a similar way to how you wash your's, which is starting from the roof and working downward. However, you are much more thorough than me!
How about cleaning the inside? What do you suggest for that job?
Thanks,
Eric
Yer me too :thumbsup:
I use the Nilfisk 110 with a foam lance from Autobright. Give a great result. Just waiting for some good weather to put some Autoglym HD polish on the old girl B)
Pre-washing a car with "snow foam" sprayed from a pressure washer fitted with dedicated lance will soak up the car better than anything.
The foam will keep moisture on the car (evenly on the whole car) considerably longer than just water coming from a hose.
I would not name brands here, some snow foams are better, others worse, but that's not the point. The spray lance also will do it's part of spraying better or worse, matches with your pressure washer and Snow Foam will be ... trial and error method.
  • 3 months later...
Great guide, there was a couple of areas I was slipping up on such as not spraying down with water after every couple of panels, so thanks very much.
  • 11 months later...
New Auto Maintenance Tools and price list
Proforfessional supplier for car maintenance
www.obdtech.net obdtech.net@gmail.com
Auto diagnosis, Code Scanner, ECU prog, Key programmer
Thisi is monica from china which is a professional manufacturer of Auto Diagnostic Tools in China. Now we have some goods are hot promotion now , detail information pls see below :
New products
JLR Mongoose for Jaguar & Land Rover US$300
DigiProg III Odometer Programmer --------$1500
VCS Vehicle Communication Scanner US$300
CARPROG US$620
BMW ICOM Plus ISTA/D ISTA/P software US$1,200
GM MDI for all GM car US$1,650
Mitsubishi MUT-3 US$1,000
Tango key programmer US$1,650
ND900 key programmer US$500
BMW Multi Tool US$850
Promotion product
We are large manufacturer, some products price is much lower than market,
following is some sell well products for 3pcs quantity:
BMW ICOM A+B+C --------------------------------------------------------------- US$700
Benz C4 star SD connect best quality ------------------------------------- US$630
Benz star HDD V2012.01 ------------------------------------------------------- US$110
BMW OPPS best quality & true function ---------------------------------- US$600
BMW GT1 high quality ---------------------------------------------------------- US$280
Ford VCM high quality ----------------------------------------------------------- US$320
VAS5054A bluetooth more steady ----------------------------------------- US$95
Toyota Tester II best quality for Toyota------------------------------------ US$600
GM tech II with card best quality --------------------------------------------- US$840
Honda HDS diagnosis ----------------------------------------------------------- US$90
Autocom CDP PRO 2011 (more chip, steady,car ) --------------------- US$130
Autoboss V30 original diagnosis -------------------------------------------- US$1,150
Autel DS708 original diagnosis ---------------------------------------------- US$1,030
X431 Diagun (60-110 car) --------------------------------------------------- US$660
SBB key programmer ----------------------------------------------------------- US$95
DSO-2250 Oscilloscope -------------------------------------------------------- US$220
PS150 Oil Reset tool ---------------------------------------------------------- US$140
Multi@diag diagnosis ---------------------------------------------------------- US$420
BMW OPPS for OPS function ------------------------------------------------ US$550
Benz C3 star best for new car ----------------------------------------------- US$270
Toyota Tester II high for Toyota,suzuki ---------------------------------- US$560
GM tech II normal quality ------------------------------------------------------ US$680
Renault Clip high quality V17 ------------------------------------------------- US$125
Renault Clip best quality V17 ------------------------------------------------- US$130
Lexia-3 Best Citroen/Peugeot ----------------------------------------------- US$93
Lexia-3 high Citroen/Peugeot ------------------------------------------------ US$84
Nissan Consult 3 ---------------------------------------------------------------- US$380
Nissan Consult 4 ----------------------------------------------------------------- US$390
Volvo Vida Dice ----------------------------------------------------------------- US$160
VAG-COM 11.2 FT232BL chip ------------------------------------------------ US$23
VAG-COM 11.6 FT232RL chip ------------------------------------------------ US$20
AD100 key programmer ----------------------------------------------------- US$123
AD900 key programmer ------------------------------------------------------ US$110
AD900 key prog (include 4D) ------------------------------------------------ US$160
Dash universal odometer adjustion -------------------------------------- US$16
Fuel Injector Cleaner Machine――――――――――――――$470.0.00
More products pls visit our website:
Co: ObdtechTechnology CO., Ltd
Website: www.obdtech.net
Add: Futian District, Shenzhen, Guangdong, PRC
E-mail: obdtech.net@gmail.com
MSN: obdtech1@hotmail.com
Skype : obdtech1New Auto Maintenance Tools and price list
New products
CARPROG US$620
Promotion product
Skype : obdtech1
I'll throw in my tuppence worth. If there is visible 'muck' on the bodywork I hose for five minutes then use a brush. I might then go over with a wool mitt (new bucket of soapy water) if it still looks mucky, and then rinse with hose before drying with a chamois. I've not found a synthetic material that dries better than a chamois.
  • 1 year later...
