Missfire
49greenie
Hi my carina e has started running on 3 cylinders after about an hours driving. I have replaced the plugs and it made no difference. The leads seem ok can anyone help please regards Dave
Probably a faulty injector. Isolate which cylinder isn't firing then swap the injectors around. Once identified try some injector cleaner before forking out for a replacement.
Thanks gazza I will try that first.Regards Dave.
Dear All,
What is the best way to clean injector? In Halford, there are many of the additive fluid of injector cleaning. Any recommendation of fluid?
Or, what is the other recommendation?
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
