Changing Bulbs ?
Toyota3000
Hi
Just realised one of the bulbs is not working (on the passenger side) - tried to unscrew (if that's the right word) the plastic bit that's connected (with the wiring etc...) so I could get to the bulb itself.
Unfortuntaely, it's placed in a really awkward position (as you guys probably know) and it was virtually impossible to unscrew the plastic bit :(
Can someone help me out ?
Thanks.
try removing the cold air feed and taking the Battery out, when i changed my bulbs i did that and it made things a lot easier. the drivers side is ok to change its just the passenger side is awkward as theres loads of stuff in the way
