Creaky Clutch
darren ta
My car has developed a creaky clutch and seems not to return as it should (if you pump it the sound changes to a squeak the sound comes from under the windscreen not the pedal )ive been told it may be the servo anyone had this or a idea of cost ???
please help
its a 2ld diesel t3x with 13000 miles
had the same problem. first they replaced a part on the gearbox but it didnt solve the problem and then replaced the master slave cylinder. luckily mine was under warranty. if you lift the bonnet and depress the pedal you can hear the clunk rather than the squeak you get from within the cabin. my pedal seemed to stick slightly on the way back up as well.
Sounds like it is the master cylinder creaking. We have replaced plenty, the didnt fail and the clutch/gearchange was fine but the noise is very annoying. If still under warranty go and get it replaced FOC.
Mart
