Air Con Coldness
Corolla In France
Hello,
I have a 2007 Corolla 1.4 D4D with electronic climate control. We used the aircon in 17 degrees c exterior weather and it took some time to get the interior cool in the car after the car was sitting in the full sun. It was set on max cold with full fan. It was blowing cold but I would of thought it would of been blowing out very cold.
I found it was a bit colder and more forcefull with the recirculation button pressed.
How cold is your AC on your corolla or Toyota in general?
Do you find it cold enough in up to 90 degree farheinheight? As in very hot weather I would more than likely have it set on max cold all of the time as I feel the heat. Many thanks James.
