Speaker Question
Matty NE
I'm a newbie so please forgive if this has been ask 100's of time before but..
Whats the speaker sizes in a 54 T sport?
10cm dash, and i think the original doors are 13cm built into odd shaped plastic. However if you change them you would fit 10cm dash but 17cm Speakers for the doors with an autoleads speaker spacer adpter that lines up the holes and spaces the Speakers for fitment of aftermarket ones. It also contains plugs to make the Speakers plug and play for the doors :thumbsup: Alternatively you could build a spacer from MDF and connect them up by soldering/crimping as you would the dash. If you do a search you'll get more infor and also if i didn't make any bit too clear!
Speakers are a good start as the standard system is pretty poor. Set of door components and 10cm dash with an aftermarket stereo and a sub would be a pretty decent set up imo.
