Airbox Problem
lemar 2005 yaris t sport
my air box keeps popping out of the lugs at the back when i hammer the car, but the clips at the front are still clipped on. its got a tte panel filter in it i have took it out and fitted it god knows haw many times its fitted correctly, do you think its the filter or the box? any body else had this trouble??
Fitted the tte filter with no problems althought i did manage to half clip the back in once which could be what you've done, just make sure you really wedge the back in.
if thats not the problem, it could be that the plastic bits on the back are bent abit which could be fixed by removing the box and covering the catches with epoxy resin or such, just to give them some more strength as plastic does fatigue very quickly once they have been over stressed.
Hope this helps, would be glad to show you how to do it or even do it for you if you were ever near bicester, or it could be done at a meet in about half hour.
Brad =)
