Help - Come On You Guys Help Needed
Wolves on fire
Hi lads/lasses.
I have a Beams powered ss111. The water pump has gone.
Do any of you know the part number or know if they changed it for this model. I am asking as the standard cambelt does not fit. As you lot know the car is vvti so has been changed to accomidate this, but have toyota changed the water pump aswell???????
You input would be greatfully accepted.
Also where can i get one from.
looks like tis the same for all 3sge's
161100-79135 - Water pump assy w/o cover
16100-79225 - Water Pump assy
Thanks lads. After many hours trying to find some info out, I have had many prices from £27.00 upto £170 from some guys in Essex. I have decided to order one from Toyota as that is the only way i know it will be the right one. Total cost is £118 so not that bad really for a main dealer.
Thanks again for your help.
