Dodgy Surf Windows
grant m
Can anyone help? The windows on my 3.o ssrx seem to be giving up one by one. I know the window motors are ok. Can anyone tell me if they are controlled by rellays and if so,where are they? Maybe this is a common problem,if it is does anyone know the fix for it?
  • 2 months later...
I'll reply to your post, as nobody else has the common courtesy to do so.
Try checking the main switch panel on the drivers door, check/clean the door switches , and check the fuses.
Lubricate the rubber seals around the windows to help the glass slide, and log on to another forum where people are willing/able to help you.
Try;
http://www.hiluxsurf.co.uk/forums/
http://www.toyotasurf.asn.au/forum/
http://forum.difflock.com/
Robert
