i just recently bought a corolla gti (ae92) high torque model, i am going to buy a full induction kit but i heard that they slow these cars down ?, can someone please advise me on this, thanks.
yep they dont like em. best bet is get a panel filter (blitz etc) this will give you the gains without the hassle.
yeah, i was thinkin of doing that and i was told to then drill the airbox so the air-flow meter can still be attached, im then thinking of making a cold air feed from the bumper?
4age tuning is best recieved with difrent cam shafts. You will lose some lower rpm torgue but regain it in higher rpm's (5k +)
THe 4age does have a need for a good in and exhaust system but then again the power gain is minimal.
thanks, can u recommend a cam for fast road use as i dont want lumpy town driving.
cat cams in belgium got some nice options. Also becuase the first to sets are very good without modifing the valves and shims. Thought the second type will take away lower rpm torgue.
www.catcams.be
seems kentcams in england should be able to produce the same.
