Back Wiper Blade
Gardner61
hi anyone who can help me
the back wiper blade of my avensis has disintergrated and no motor factor has a new blade they keep selling me these cut to size crap which i bend when it has to be re fitted.
can anyone tell me if there is a secret clip which lifts the arm up or where i can get a new blade for my car
it is a '53 plate new shape avensis
please help!!!!!!!!!!!!!!!!!!!!!!!
Hi there,
My Avensis also needs a new rear wiper, as the rubber is peeling away. I had it in for a service earlier in the week, but it has to back on Monday for new tyres and for the blade to be fitted (they have to order the part in). It might be worth seeing if your local dealership can do it for you, although I imagine they'll be more expensive!
The wiper arm is held on by a 10mm nut which is covered by a plastic shroud. Simply place your fingers either side and underneath the shroud and ease outwards until it unclips. If your cut to size blade still doesn't fit, use a genuine Toyota replacement rubber with your old metal side runners, which should be ok.
