1994 St205 Gt4 Subframe Bolt Movement?
devils_tale
Hiya Guys,
i finally got the the gt4 im looking to buy on a ramp and found the front passenger wheel had a little play in it.... ive been told the arm going to the sub frame from the tyre seems to be a little loose, which occurs when the the tyre is moved back and forth, the guy who looked at it said it may be a loose bolt......anyone got any thoughts
apologies in advanced for the fault/problem description ...not to sure how to explain the problem
i found this pic...which shows the arm im on about...i think is the called the control arm
http://www.gtfours.co.uk/pics/suspension/205/002.jpg
Ja
yep fairly common problem to be fair. you can get the arm from TCb (toyota celica breakers). he sells brand new genuine toyota ones but they are about £250each IIRC and the smaller FIG 8 (links the arm to the strut is about £90.
wear in either can cause the wheel movement you described.
ian at TR&D is prolly the closet place to fit it and i think itll be around £40 for one side.
