Drivers Door Lock
dkan
The door lock on my mum's N-reg Corolla is playing up, the key can no longer unlock the door. Maybe that the lock/barrel is knackered as the key works fine on the passenger side. Can you fix these barrels and is is easy to DIY ? Or to make it more convienent for mum, can is just swap the barrel/locking mechinism over from the passenger side. Don't fancy having 2 keys for the car....mind you think the barrel for the ignition is starting to go too :(
