Wheels Rubbing Off Arcsh?
maligo-joe
Please advise,
Have a rolla e11 hatch, stuck 195x50x15 speedline comp 2's on her. lowered the back on 35mm Eibach springs and shes rubbing coming out of corners with no one in the back. I'm afraid to lower the front now. I was told that if I get the arches rolled it will stop, is this true? Also, does anyone know where I can get them rolled if it will work, in the dublin area though. Thanks in advance,
Joe
Doesn't take much to roll arches, most body repair garages or restoration garages should be able to sort them for ya! surprised its rubbin tho on 15" :unsure:
but maybe u could try some 195-40-15! the tyre wall is alot shorter then
that is perculiar :blink: i've got 35mm lowring and 15s on but i'm using a 185/65 profile so if i were you i'd examine you shocks to see if they've given up.
hope this helps :thumbsup:
