How Do You Change A Gen6 Headlight
Cardboard
Any ideas on how to change the drivers side low beam housing? The outermost (larger) glass headlight has smashed, and I think I'm going to need to change the whole housing, rather than get a replacement glass? Does that sound about right? And if so, how? Some parts don't look like they can be reached easily.
Hope this makes sense!
I can't remember the full process but I'm sure it's been discussed on here before, from what I remember the whole bumper has to come off
The BGB for gen 6 doesn't work (on the pinned post), has anyone else got a copy I can have? Maybe the instructions are in that?
-remove the arch lining round the front wheels
-then on the inside you will see where the wing is bolted to the bumper, undo these bolts
-Undo the bolts that are under the bonnet in the engine bay.. about 4 or 5 along the top i think
-Might be some differences with yours and mine though as mines a 205
