Screenwash Gunk, How Do I Drain It?
Jovensis
My screenwash comes out like jelly and makes more mess than it cleans, does anyone know how i can completely drain the bottle and start afresh.?
Cheers Jo
No idea how to drain, but you could run the jets continuously for a while and add pure water, to see if this dilutes the effect?
If it is a gloop then not sure the washer jets would cope, but if they do then run them until bottle is empty, flush, and use the washer again until clear.
Otherwise you could pop a hose in the washer bottle and blast it that way, but you may get some gloop left in the bottle.
I've put in some awful screenwash in the past and used the hose/syphon method, minding I don't get a mouthful in the process.
I find the Halfords flower smelling screenwash is the best for not going off in the screen wash bottle.
Cheers for that :thumbsup:
i have only put water in it so far in the hope that I can get rid of it but it seems to be a never ending well, think I'll try to syphon it out, a mouthfull won't hurt, after some of the vino I've drunk in the past it'll probably be quite palatable :lol:
