Key Fob Reprogramming
David20
Is it totally safe to use the procedure for reprogramming an Avensis key. I have an Avensis X reg model, and its working on one key, and I have a spare key that I would like to program. The alarm on that key works, but it simply doesn't start the engine. I would like to know if using the guide to programming the key will do anything to the key I have working at the moment.
Any help will be much appreciated. Thank you.
