Servicing/parts Specs Info Needed
ek4
about to buy X reg 5 dr gls yaris for family member which im gonna end up doin little servicing bits in future but need info on what service intervals are and what actual toyota service book says needs doing at each interval
also need to know what toyota dealers use for -
spark plugs (brand and model no)
engine oil grade they use and is there prefered brand (i gather this will vary from dealer to dealer )
brake fluid spec
mtf spec
oil filter (oem toyota preferred on toyota scene ?)
anythimng ive forgot to add please add
thanks in advance
It may be a good idea for you to get the Haynes Manual for the Yaris.
It helps with all of that type of information..........................but does not cover the TSport or MMT models.
ok, just bought the car for my mum, probably will buy manual but any work more involving than changing fluids will be done by mechanics
just looking for specs on items i listed that toyota recommends/use at the dealers
