Vibe Qb69 Square 6x9s
Hou
Vibe QB69 Square 6X9s
For sale:Vibe QB69 Square 6X9s in a 18mm MDF Carpetted parcel shelf made for the ep82
Item Condition:Seen better days but still working, not sure where the grills or crossovers are
Price and price conditions: 40 quid ono ( these are 80 quid min on ebay)
Extra Info:
Revolutionary world exclusive design concept of a rectangular shaped 6x9 speaker catapulted VIBE to the forefront of the car audio industry.
The unique rectangular form provides more than 20% more surface area than a regular 6 x 9, resulting in greater air movement and increased bass response. The subwoofer motor structure supports an ultra-stiff rectangular IMPP* cone which is suspended in a radically designed surround to produce precise lateral cone movements, delivering low to no distortion and clean PowerBass™.
SPECIFICATION:
Configuration 2-way
Speaker Size 6x9" Rectangular
RMS Power 200w
Peak Power 600w
Sensitivity 93dB
Frequency
Response 30 - 25,000Hz
Impedance 4ohm
Mounting Hole 170x220mm
Mounting Depth 100mm
Recommended Amp BlackBox II, III
Pictures:Can be sent on request
Contact Details:pm or text 07930811052
Delivery & Conditions of Delivery: Collection prefered if wanting the parcel shelf, if only wanting the Speakers can post for an extra tenner (they weigh a tonne)
yeah cool, i sometimes need to take my parcel shelf out depending on equipment is there like a way you can make the wires short and put like a plug connection or summat?
Yep, have a look on maplins site. either jack plugs and sockets, or XLR plugs and sockets will work nicely. Both designed for audio. jack is cheap and cheerful, but may become disconnected, or generally just a bit rubbish over the course of time. XLR's are fantastic, and lock in to each other, with much better connectivity that'll stand the test of time, with the slight prob that they're a bit heavy (few hundred grams - so nothing major!), but might still pull on your wires a bit if you're not careful.
I did a mates install in a Corsa many moons ago... 2x 6x9 in a custom parcel shelf, and XLR plugs on the end of each speaker cable. Then put some flush XLR sockets in the plastic covering in the inside of the boot, and just colour coded them for left and right. Worked a treat. :thumbsup:
Yeah as above these are easy to do, although i really wouldnt recommend using these in a parcel shelf thinner then mine, i have em in a 18mm mdf shelf and its starting to sag slightly from the weight!
eek i only have a standard one :(
and we use XLR's to connect mics to cameras, 3 pin yeah?
well if i could be bothered i could make you one, but i cant!
All you need is about 20 quid for the wood and carpet, a jigsaw, drill and staple gun!
