Falling Revs During Braking
olobolo
Hi
Recently i noticed that when I'm am about to stop the car the revs are dropping below 500 - something around 450-500. When I release the brake pedal the revs are going up to normal idle state 550-600. When the car is stopped and I press the pedal again the revs drop a little bit again.
Is it normal or have to do with brake pump or something else? Should I worry and go the garage to check it out? Anyone can help?
btw.
I've put this also on TS'es board as not all of you take a look there. Sorry for the double post.
got the exact same problem
havent a clew wat it is
but the car feel like it wants to stall
got told it might be thin oil?
What oil do you use? On mine I have fully synthetic MOTUL 8100 XCESS 5W40
semi something something 10 W 40 is that good?
I'ts good - but depends on the manufacturer ;)
its probably cos the brake pumps and stuff are running when u press the pedal and the lights too, more load on the engine.
I wouldnt worry about it. Mine idles at about 450-500 rpm normally and its happy.
ah i see oh well ill try the 10 w 5 next time
but aye probs the amps draining the Battery aswell as all the other stuff
