When I turned the key I was getting a clunk and the engine did not turn. Subsequent turns of the ignition it was okay. So I checked the Battery and there was a clear indicator which means 'No charge'. Well the Battery is over 3 years old so I bought a new one from Halfords and had it fitted. Got the car home and the ignition is still 'clunking' and does not turn.
Is there anything else I should be looking at?
Could possibily be a problem with the starter motor?
Heard of similar symptoms and its turned out to be the contacts on the starter
If it is the starter motor, how much am I looking at?
It could just be the contacts which wouldnt work out that expensive and as far as I am aware is a fairly straight forward job.
Try looking at www.estimaownersclub.com there are a few discussions on there regarding starters plus a few people who have done them before
Yep...starter contacts on the solenoid wear out over time - this gives the dreaded clunk/click but no current to the starter. Starters very rarely fail on these buses - only know of one that has!!!
Cheap and easy fix - part comes as a Contacts "kit" from Toyota. Don't know about the Previ, but Esti's can certainly be repaired with the starter and solenoid in situ (just pop the solenoid cap off - AFTER you've disconnected the battery)
the link above is a good one if you're running an Esti, Previ or Aces :thumbsup:
