4age Injectors Need Advice!
corolla_gti_4age
basicly ive got a standard 4age in a ae92 all thats done is twin cold air feed straight to the standard air box plus full s/s system but the back box has had the exhast wadding removed as the last ownwer wanted a s/s exhuast but didnt want it loud!! paid £410 for it what a rip off
any way to the point ive seen these 200cc per min injectors but it dosnt give a gemreal bhp gain can any one give me a idea of gain or if its even worth it
also would i need to remap my ecu?? and is that expencive, any comments or help on any of this would be great
cheers matthew keys
Hey,
you don't need to remap your ecu. It can calculate a pretty good hp increase. (around 140 -150 is doable)
If you want more power rather think camshafts in a 4age. The intake and exhaust are already done. With remapping the ecu (so called Chiptuning) Is a waste of money as you won't gain more than 3 of 5 hp for alot of money.
Making the 4age ecu remappable will probably cost more than a good set of camshafts that drop right in. (with the correct shim adjustment)
