Wheel Nuts!
alan589
Hello
I was trying to fit alloys to my Corolla today 96 Ae102 4e-fe. The wheels have the correct offset and pcd but when the wheel is on the hub there is not enough of the wheel stud sticking out ie i can only get the nuts on halfway.
Has anyone else enountered this problem and is there a straightforward solution other than just sticking the steelies back on? :help:
Ta
Alan
Hi are you changing from steel wheels to alloys?
If you are and you are using your nuts from the steel wheel then it wont work. You need to buy some alloy wheel nuts as these are longer.
If you are changing from alloy to alloy...then you have a problem!
Hi smoftah
Yes I am changing from steel to alloy and I am using the original nuts. Are we talking about the same thing? These are old fashioned wheelnuts, not bolts, ie just the hex bit with no bolt attached?
Alan
Hi smoftah
Alan
Yes mate you need to get some new wheel nuts specifically for alloy wheels. :thumbsup:
Hi smoftah
Alan
Hello
Thanks for replying. Are these alloy nuts easily availible?
Alan
can get them in any tyre/alloy outlet, normally they are supplied when you get new alloys fitted
A good motor factors should be able to supply you a suitable set.
Thanks Guys
I will go shopping for these at the weekend
Alan
