Wheel Nut Type
den9112
hi, mi have a 96 rav4 gx with steel wheels , i have just purchased a set of toyota alloys to replace the steel ones. my whel nuts on the steel wheels are different to the ones i need on the alloys . could any help me with what i need . on the inside of the wheel it says 16 7j . thanks
Wish I could help - when I bought alloys which are MSW (not TSW as I said in another post or is it the other way round??) the chaps fitted new bolts and I was left with a box of old bolts. However the chap I use - Autoimage in Glasgow - has a massive crate of wheel bolts. I'd imagine any alloy wheel supplier will have the same excess bolts that would fit your wheel. If you look through recent posts on this forum, this week, there is a guy looking for steel wheels!!
good luck
I'm afraid I can not help you with the wheel nuts. But when you have your alloys fitted, Let me know if you want to sell your old steel wheels!
when i get the wheel nuts i will be fitting straight away , so i would be hoping within the next week . i will only have four as i need to keep a spare . if you send me your email i will send you a photo of the wheels
  • 4 weeks later...
please e-mail photos to squealeyhealey@hotmail.com. Where abouts in the country are you located?
Andy check eBay , some steel wheels on there.
den you need either flat top washer type nuts or chamfered nuts for the alloys.
I would say the nuts for the steel wheels are chamfered. You will most probably need the flat nuts with washers for the alloys.
Go to your local Toyota dealership, the parts dept should be able to give you part numbers for the nuts you need very easily.
When you find out i should be able to find a set of what you need at work ;)
Mart
