De Badging
Joel13
use fishing wire or dental floss to cut down the glue at the back.
use meths to rub off the old glue and sticky foam. (you will need to give it a good rubbing as it's stubborn to get off)
bit of t-cut, polish or wax to finish off.
If under certain lighting conditions you can see where the Badge was (sometimes leaves a blackish mark where the Badge was)
just give it a rub with t-cut and should come off.
any tips when coming to de- badge my TS?
if you got a mini steamer the sort you can get in argos they work a treat, then bit of wd40 on a rag to wipe off the left over adhesive.take your time it pays in the long run you dont wana mess it up :(
