Fuel Pump
LuBee
Hiya,
I was just wondering whether anyone else has issues with starting their engine when the car is parked facing uphill?
Has anyone replaced their fuel pump and did it make a difference?
Not running low on fuel are you when your are on the hill?
What Dave said :thumbsup:
If its low on fuel chances are it'll run away from the fuel pickup
Nope. I think I will try replacing the pump.
Might just be that the 4 throttle assembly needs more juice than my pump can give it on a hill.
Thanks guys.
I would change the Fuel Filter first and if that has no effect,remove the fuel pump and check the filter sock on
the pick up pipe - they can get partially blocked.
