Reset Abs Dash Warning Light
Ted W
Hi All,
Yaris 1.0 2002
The ABS warning light came on, I checked all the wheel abs sensors as per the haynes manual, and found the n/s front to be well low on ac voltage output (this was also confirmed by Mr T's diagnostics).
I've purchased and fitted a secondhand abs sensor from a scrap yard which shows the same ac voltage as the other 3 good sensors on the other wheels but the ABS Warning Light is still illuminated.
How can I reset the ABS Control Unit? Resetting the ECU (ie disconnecting the battery) doesn't seem to reset the ABS Warning Light.
kick it and shout abuse at it :P
the dudes will be along sure with a way to fix ur dilema soon i would guess
